kefferjoe Posted July 9, 2012 Share Posted July 9, 2012 Anyone know how to remove the antenna from the fender without breaking it?? I can't figure it out. Link to comment Share on other sites More sharing options...
clkindred Posted July 9, 2012 Share Posted July 9, 2012 What part? Just the telescoping mast or the whole thing servo and all? Link to comment Share on other sites More sharing options...
kefferjoe Posted July 9, 2012 Author Share Posted July 9, 2012 Well I need to replace the fender so whatever the piece that is embedded into the fender Link to comment Share on other sites More sharing options...
clkindred Posted July 9, 2012 Share Posted July 9, 2012 (edited) You will need to remove some of the wheel well plastic to gain entry into the fender. Then there is a little chrome "ring" at the base of the mast on the outside just on the fender's surface that partly attaches the entenna to the fender. Unscrew this part and remove it. Then on the inside of the fender, you will see just one or perhaps two bolts holding the servo motor/inner antenna assy. to the vehicle. Remove these aswell as the related wires and it will drop out of the fender. Hope this helps! Edited July 9, 2012 by clkindred Link to comment Share on other sites More sharing options...
bushnut Posted July 28, 2013 Share Posted July 28, 2013 well I just broke that very same piece. The "Chrome ring" would not turn, in either direction. ended up snapping the plastic piece that I would call the mount. note...not the electric antenna just the basic one. I've been thinking about mounting it up inside the fender and filling in the hole. I suppose that would ruin my reception? but it would look clean. Any Ideas? Link to comment Share on other sites More sharing options...
