qatcool Posted June 24, 2012 Share Posted June 24, 2012 Its been a year since i bought my Pathy, i replace all under - chasis bushing, ignition coil,spark plug, and fuel filter. but 1 concern that i dont know how to address is the shift shock, you can feel the transimission shifting especially from 1st to 2nd gear, according to my mechanic its normal, sometimes the shifting is smooth when i rev up to 3500. anybody here can advice? Link to comment Share on other sites More sharing options...
madhornet Posted June 24, 2012 Share Posted June 24, 2012 i have had some do and some dont Link to comment Share on other sites More sharing options...
ahardb0dy Posted June 24, 2012 Share Posted June 24, 2012 (edited) possibly someone installed a shift kit in the trans giving it firmer shifts? Edited June 24, 2012 by ahardb0dy Link to comment Share on other sites More sharing options...
Towncivilian Posted June 24, 2012 Share Posted June 24, 2012 (edited) NTB01-055a - 2001 PATHFINDER AUTOMATIC TRANSMISSION 1-2 OR 2-3 SHIFT FLARE What's the level and condition of the transmission fluid? 1. Drive around for 10 minutes in the city after the transmission is at operating temperature. 2. Park on a level surface and apply the parking brake. 3. With P selected, shift through every gear and return to P. 4. Pull the transmission dipstick with the engine idling, wipe it clean, reinsert it completely, and read the level. It must be within the notched area labeled "HOT". Check for fluid contamination after wiping on a paper towel. The fluid should be red, and not smell burnt. Edited June 24, 2012 by Towncivilian Link to comment Share on other sites More sharing options...
theexbrit Posted June 24, 2012 Share Posted June 24, 2012 My 96 shifts a little hard from 2nd to 3rd also, it's not that bad but definitely harder than the other gears. When it warms up it's a lot better. Link to comment Share on other sites More sharing options...
Tungsten Posted June 25, 2012 Share Posted June 25, 2012 If your transmission shifts harder, it will last longer. Link to comment Share on other sites More sharing options...
Kyle94 Posted June 25, 2012 Share Posted June 25, 2012 ^ this lol. my issue is the opposite. i cant feel the gears unless its cold. lol. then it feels like its just one gear. D: srsly though, harder shifts are better (not slamming gears) for the trans than the gears sliding and engaging. Because obviously the sliding causes the cluth packs to wear down faster.. Link to comment Share on other sites More sharing options...
qatcool Posted July 1, 2012 Author Share Posted July 1, 2012 I asked 1 of a mechanic, and he just adjusted the TPS, I dont what it is, i believe its throtlle position sensor. and its ok now. he informed me that it is shifting late. Link to comment Share on other sites More sharing options...
Tungsten Posted July 1, 2012 Share Posted July 1, 2012 That makes sense. Disconnecting the TPS makes the shifts late and rough. I can see how a TPS out of adjustment can cause it. Link to comment Share on other sites More sharing options...
