Rafaguerra2000 Posted June 17, 2012 Share Posted June 17, 2012 Can anyone give me a tip on how to check the 4wd indicator light. It was working properly but after a frame change its no longer working. The actual 4x4 seems to work fine. Thanks Link to comment Share on other sites More sharing options...
Tungsten Posted June 17, 2012 Share Posted June 17, 2012 Let's start with the easy part... Is the bulb burned out? Then you may have to check if everything is plugged in. Link to comment Share on other sites More sharing options...
silverton Posted June 18, 2012 Share Posted June 18, 2012 probably the bulb. it's just a dummy light, check the t-case shifter if you need to make sure. Link to comment Share on other sites More sharing options...
Slartibartfast Posted June 18, 2012 Share Posted June 18, 2012 You might also check the wiring around the transfer case and trans. Link to comment Share on other sites More sharing options...
GSeijo Posted June 19, 2012 Share Posted June 19, 2012 reminds me of mine...turns on whenever the hell it wants, but 4x4 works fine so I don't worry too much. Link to comment Share on other sites More sharing options...
Mr.510 Posted July 21, 2012 Share Posted July 21, 2012 There are two switches on the passenger's side of the T-case, one of them turns on that light. Mine stopped working a while back and I figured it was the just the bulb. I was under the truck adjusting my RH T-bar that had sagged a little and noticed the wires are ripped out of both switches. A rock or chunk of wood probably got up between the T-case and the frame and re-arranged things at some point. Can't imagine how that could have happened as I only drive my Pathy to church on Sundays.... Link to comment Share on other sites More sharing options...
