GSeijo
Everything posted by GSeijo
  1. you are describing exactly what happened to mine a year ago, it is also a 93 pathy. Had to get a new master kit, tranny band, cleaned the torque converter, replaced the neutral switch and of course changed the tranny fluid and replaced the filter... it's been a year and has worked fine since then... good luck on yours.
  2. sorry for the late reply guys and thanks for the comments. Two days ago I was driving, filled up the tank and it didnt mark anything until like 30 minutes after that it started going up, since then it's been work fine so I'll leave it like that and see if it gets bipolar again haha.
  3. Today I went to college, everything was ok, I parked, went to class, when I go back to the pathy I noticed the fuel gauge was marking empty ( empty as in the red indicator was like 1/4 inch lower from the empty line). I know I had almost 1/4 tank left so I drove home. When I got home I got underneath the pathy to check if it was leaking or something but everything seem normal. I don't know almost anything about fuel systems so any sugestions will do. Thanks guys.
  4. need torsion arm...broke the one in the drivers side yesterday.
  5. crazy to go wheeling after the storm over here in Puerto Rico but can't find a partner and my unbreakable rule for wheeling is never go alone in one car, at least two trucks.
  6. That might explain why the two locksmiths I took the cylinder to had a hard time making a copy. I took out the drivers side cylinder. Thanks for the advice, I'll keep it in mind.
  7. I'd say lizzard or turtle, but hey, I'm no biologist. Are you sure those aren't ping pong balls? lol, just kidding.
  8. any ideas on why my wd21 starts like failing when it rains, like if water got in as in if I had crossed through a flood or something and water got in. When I'm in complete stop and when going in low rpms it starts failing.
    1. GSeijo
      GSeijo
      Imma go check the distributor cap isn't cracked or something. It's the only thing that came to my mind
    2. Tungsten
    3. GSeijo
      GSeijo
      Yup, it was the distributor cap, but it wasnt cracked, somehow one of the screws managed to unlock itself.Changed the screws with some new ones :)
  9. ok, I'll look for it around the forum. I hope to buy it thursday/friday and mount it saturday. I'll upload some pics, I envy your 5 speed, I want to make the swap very badly.
  10. That's mean Nunya, I like miatas! Can't say the same for Metros I already checked the trans. cooler with the Pepboys around the corner, they have a couple available, are they easy to install? or will I be breaking my head trying to mount it?
  11. hahah I'll go to a locksmith tomorrow. The first key to break was almost two weeks ago and it wasn't me, My mother wanted to look for something in the my pathy, so I gave her the keys, she puts the key in the drivers side door lock and turned it to the wrong side. Second and last key, I arrived at the university, took my class, when I got out and went to the pathy, surprise surprise I only had half a key in the key chain. I have no idea how or where it broke but it probably was in the ignition, funny/ scary part is that I can turn on my pathy with my small pocket swiss army knife and also with the half I still got of the second key that broke, if I play with it in the ignition I can manage to unlock the cylinder and turn it. But I need the new keys ASAP, I can't be leaving the pathy around unlocked... Thanks to everyone for the suggestions! As always, I'm most gratefull for the help and hope I can be of your service sometime.
  12. ok since I don't have both halves of the keys I'll take the door lock cylinders to a locksmith. About the tranmission, I guess I'll buy an aftermarket one this week. I have no Idea what the previous fix involved,The receipt says somethings about motor kit, converter, neutral switch and a band. And obviously the flushed the transmission so new trans oil and filter.
  13. Also, so I don't need to start another topic. I travel long distances couple times a month, I've been noticing that after a while driving the center console gets very hot. What should I do? Is it the transmission? Should get a Transmission Oil Cooler? The transmission was fixed about 9 month ago ( it's auto, I so want a swap for a manual).
  14. reminds me of mine...turns on whenever the hell it wants, but 4x4 works fine so I don't worry too much.
  15. So I broke my 2 keys for the pathy. What do I do now? Do I have to get a new ignition switch with its lock cylinder and keys or only the lock cylinder with keys? And obviously at least driver's side door lock cylinder with key. Idk what would you guys recommend? I really don't care if the door key and the ignition key are different.
  16. Would you guys believe me if I told you I just broke my only two keys for the Pathy? I just did.
    1. nunya
    2. GSeijo
      GSeijo
      haha I wish it was a lie!
  17. First one wasn't in a pathfinder, was in a friend's 89 Montero, the middle part of the trail was a high and the Montero was basically lifted from the differentials( four wheel in the air) there was no one around, so we had to walk out of the trail(about 30 minutes) to look for someone who could pull us out. In my pathy going up a very steep rocky hill the engine started dying and suddenly it turned off, was there waiting for a buddy for about 4 hours, I decided to take one last look to the engine, results that the cable from the engine coil had somehow manage to come off, connected, placed adhesive tape around it and good to go. Last time, it was really my fault, hydrolocked the engine...VERY DEEP MUDHOLE! water came up to front windshield, pretty bad stuck, engine went on for about 5 minutes, finally after ten minutes managed to pull it out with alittle help from another Pathy. Had to pull my Pathy all the way to my house with a recovery strap, it wouldn't turn on, gasoline came out of the air filter...I thought it was well dead until the mechanic checked it, new spark plugs, air filter, airflow sensor and engine oil, transmission fluid, differential fluid etc and it's been working like a champ...I think I learned from that last one, now I'm very carefull when muddin'. I've seen people braking axles, differential being cracked hitting rocks, roll overs and other crazy stuff. It's part of wheelin'and muddin', you have to be prepare and never think that nothing will happen.
  18. Is the ECU for 93 WD21 4x2 the same for a 4x4 93 WD21?
    1. Show previous comments  3 more
    2. GSeijo
      GSeijo
      nice good to know, I had to get a new one and the only one I could find was one from a 4x2 and I wanted to make sure I wouldn't have any problems with the transfer case, thanks a lot buddy
    3. 1994SEV6
      1994SEV6
      the transfer case is manually shifted. The only thing the ECU does is put a little light on your dash.
    4. NissanNismoZ
      NissanNismoZ
      not a problem! glad I could help :-)
  19. sorry I took so long to reply, been very busy. I can't stop laughing since I discovered the source of the noise, turns out it was the exhaust pipe knocking against another steel bar near it. So I took an old radiator hose, cut it from one side a placed it around the exhaust pipe, no more sound. Lol.
  20. gasoline coming out from the intake?!?! WTF?!?!
    1. Tungsten
      Tungsten
      Is your distributor on backwards?
    2. GSeijo
      GSeijo
      what do you mean backwards?the mechanic is passing tomorrow to check it, he thinks it may be the injectors are bad, when a put the key all the lights come on, radio works etc but when i try to start it it "thumps" and gasoline start coming out from the intake, the battery was dead today. I have no idea what to do, I dont even have money to fix it and the pathy is my only transportation to the uniersity, I need patience, i hope i can fix it soon, any siggestions please, I will be most ...
    3. GSeijo
  21. was gonna sell pathy but I'm not able to part ways with it so im probably keeping it, if I do...new ignition, shocks and tires coming(hopefully lol)
  22. :( selling my pathy...
  23. not my week...yesterday had to get 10 stitches in a finger and lost my nail plus a bone fracture, today Pathy's transmission is begining to fail again plus an oil leak appered out of nowhere and the biggest WTF: turned of the ignition took out the key and the engine was still on, had to disconnect the battery...aaaaaaaaaaaaaaaaaaaaargh!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!...
    1. Show previous comments  4 more
    2. GSeijo
      GSeijo
      oh gosh that sounds painfull, I'm glad you're getting better, I screwed a year ago the ligaments in my left hand thumb, cast for month and home therapy but it never has been the same lol,. I wont need therapy but possibly need a surgery. But I'm ok, just taking it easy and dealing with it, part of life and well fixing the pathy bit by bit.
    3. Nefarious
      Nefarious
      ya thats what i did with my time off. did a vg33e swap and lifted my truck to fit some 33s. had to have something to keep me busy. although it took a lot longer than normal with 1 good arm! lol
    4. GSeijo
      GSeijo
      lol yeah, I thinks its gonna be more or less the same over here, difference is I'll have to be sit to work hahaha its gonna be fun I guess
  24. Yesterday had no noise, today it came back, it's coming from near the transfer and transmission shifter, it makes some kind of vibration...i don;t know if I shold worry or not lol... maybe I'll take it to my mechanic and see what he says. Thanks for the suggestions guys!
  25. Everything its pretty clean down there, anything that could've gotten stuck possibly came off after the two and a half hour highway drive I made yesterday...
