muddfildvaynes Posted June 11, 2012 Share Posted June 11, 2012 So after my last weekend of playing in the mud, my engine has decided to not start, the starter turns over and it doesn't even act like it wants to start; and it might kick over but it shakes when running and if I give it gas it dies.... I am thinking maybe I got it wet under the distributor cap? Last time it had this problem I thought it was the fuel pump, put a new one in and it wasn't the problem, then I put a new distributor in in and it was fixed.... Could the distributor go out in it again? I am hoping its not a timing problem... Any ideas? Link to comment Share on other sites More sharing options...
devonianwalk Posted June 11, 2012 Share Posted June 11, 2012 If you detect a strong odor of gas, it could be a timIng issue. Link to comment Share on other sites More sharing options...
muddfildvaynes Posted June 11, 2012 Author Share Posted June 11, 2012 (edited) no odor.... The engine just spins and it might fire up for a second or two. Edited June 11, 2012 by muddfildvaynes Link to comment Share on other sites More sharing options...
devonianwalk Posted June 11, 2012 Share Posted June 11, 2012 We always have to ask the obvious ... wait for it ... are you throwing any codes? Link to comment Share on other sites More sharing options...
shift_love Posted June 12, 2012 Share Posted June 12, 2012 i had a vg33e frontier before my pathfinder, i had a tech at work put a timing belt on it, and he didnt stab the distributor right, and it did exactly what you are saying...but since you didnt recently remove it...maybe it just shorted out in the water, its a good chance thats what happened, 240sx's older ka24de altimas are notorious for getting water in the cap and shutting down Link to comment Share on other sites More sharing options...
k9sar Posted June 13, 2012 Share Posted June 13, 2012 check for spark by taking an old spark plug, pulling a wire, put it on the loose plug and ground it to the block while someone cranks it. If it's no spark or weak spark, you have yourself an electrical issue that you can then start tracing back throught the disty to the coil. If you have good contacts (not burnt) in your disty, I would bet on a failed coil. Link to comment Share on other sites More sharing options...
XPLORx4 Posted June 13, 2012 Share Posted June 13, 2012 Check the MAF sensor. If it's dirty, you won't be able to start the engine. Link to comment Share on other sites More sharing options...
devonianwalk Posted June 14, 2012 Share Posted June 14, 2012 check for spark by taking an old spark plug, pulling a wire, put it on the loose plug and ground it to the block while someone cranks it. If it's no spark or weak spark, you have yourself an electrical issue that you can then start tracing back throught the disty to the coil. If you have good contacts (not burnt) in your disty, I would bet on a failed coil. I purchased a spark indicator when I was trouble shooting my timing issue for a couple of bucks at our local big box auto parts store. That is a great idea K9. I had not thought of that. Link to comment Share on other sites More sharing options...
