tquatier Posted January 14, 2004 Share Posted January 14, 2004 Can anyone help with this problem? My drivers side high beam quit working, It has been somewhat erratic for a few weeks, coming on a few seconds after I'd flick the switch, but now it has quit working completely. I thought it was the bulb and replaced it today but no luck, same problem. Passenger side works fine. I'm pretty sure it will be a relay problem but I have no idea where it is or how to fix it. Any help will be greatly appreciated. Link to comment Share on other sites More sharing options...
sw Posted January 14, 2004 Share Posted January 14, 2004 hi and welcome this is a very common problem pull the head light switch/indicator stork off of the steering column pull it apart and clean all the metal contacts and also bend them back down due to age the contacts bend up a little and stop touching, just bend em back down the best way to do this is to pull the switch apart completely. hope to see you round the place. steve Link to comment Share on other sites More sharing options...
tquatier Posted January 15, 2004 Author Share Posted January 15, 2004 Thanks, I will try it in the next few days and let you know how it worked, this site is great. Link to comment Share on other sites More sharing options...
tquatier Posted January 17, 2004 Author Share Posted January 17, 2004 Before I tore apart the steering column I decided to try some tuner cleaner, I just sprayed it in the hole where the switch goes into the steering column, worked like a charm, problem is fixed, thanks alot for the info Link to comment Share on other sites More sharing options...
Guest tram_bethea Posted April 12, 2004 Share Posted April 12, 2004 Hey my lights are doing that now too. Can you elaborate a little on how to take the cover off the switch of the switch? Any help would be much appreciated. Link to comment Share on other sites More sharing options...
Pathy Posted April 13, 2004 Share Posted April 13, 2004 i got inspired to fix this problem after reading this post, it was east 1-2-3 i just simply scratched the some of the crap off the metal surface between the metal pins and my high beams work once again. Link to comment Share on other sites More sharing options...
sw Posted April 13, 2004 Share Posted April 13, 2004 Can you elaborate a little on how to take the cover off the switch of the switch? remove the switch, get 2 small slot screw drivers and very gentely pri it apart Link to comment Share on other sites More sharing options...
NissanPerson Posted April 13, 2004 Share Posted April 13, 2004 Gently! That's where I went wrong! For tquatier, spraying stuff in there worked for me for about...oh...2 weeks, then it had the same problem again. I would either buy a new one (for about $80) or take it apart, with emphasis on gently. Haha. After I bought a new one I thought, "Hmm, I wonder if I could fix this???" So I tried to be patient but ended up using a hammer to open it. Well, I got it open, and I was basically just curious about the inside, and then realized I probably could've fixed it and said "oh shoot!" Of course, I said something more vulgar, but this is G rated. Anyway, good luck. Link to comment Share on other sites More sharing options...
Guest tram_bethea Posted April 13, 2004 Share Posted April 13, 2004 Hey that was easy. Thank you for all your help guys. ROCK ON!! Link to comment Share on other sites More sharing options...
tquatier Posted April 15, 2004 Author Share Posted April 15, 2004 Guess I was lucky, I sprayed the cleaner in their in january and it still is working like a charm. Krylon electrical parts cleaner. Link to comment Share on other sites More sharing options...
