Help with high beam headlight
tquatier
Can anyone help with this problem? My drivers side high beam quit working, It has been somewhat erratic for a few weeks, coming on a few seconds after I'd flick the switch, but now it has quit working completely. I thought it was the bulb and replaced it today but no luck, same problem. Passenger side works fine. I'm pretty sure it will be a relay problem but I have no idea where it is or how to fix it.
Any help will be greatly appreciated.
hi and welcome
this is a very common problem
pull the head light switch/indicator stork off of the steering column
pull it apart and clean all the metal contacts and also bend them back down
due to age the contacts bend up a little and stop touching, just bend em back down
the best way to do this is to pull the switch apart completely.
hope to see you round the place.
steve
Before I tore apart the steering column I decided to try some tuner cleaner, I just sprayed it in the hole where the switch goes into the steering column, worked like a charm, problem is fixed, thanks alot for the info
  • 2 months later...
Guest tram_bethea
Hey my lights are doing that now too. Can you elaborate a little on how to take the cover off the switch of the switch? Any help would be much appreciated.
remove the switch, get 2 small slot screw drivers and very gentely pri it apart
Gently! That's where I went wrong! For tquatier, spraying stuff in there worked for me for about...oh...2 weeks, then it had the same problem again. I would either buy a new one (for about $80) or take it apart, with emphasis on gently. Haha. After I bought a new one I thought, "Hmm, I wonder if I could fix this???" So I tried to be patient but ended up using a hammer to open it. Well, I got it open, and I was basically just curious about the inside, and then realized I probably could've fixed it and said "oh shoot!" Of course, I said something more vulgar, but this is G rated. Anyway, good luck.
