Speedometer problems...
NissanNismoZ
I didn't think the 1995 model's had a problem with the speedometer..but.. here goes.
About a month ago, i noticed as i was accelerating..the speedo wasnt moving..stared it down and it suddenly jumped to where it was supposed to be..thought it was just a glitch, nothing serious, so i ignored it..well. Today, i noticed its getting worse, but slowly. several times today it wouldnt do anything, i tried hitting the dash, thinking it may be a loose connection, and nothing. It seems once it finally works, it works fine through the whole trip. BUT. I have always had speed sensor codes, which triggers the CEL...and it's actually stayed off for a while and has come back on..but to my understanding:
The speed sensor runs to the dash, to the ECU.Right?
I've done some searching and found the only Pathy's that seem to have the problem are the ones with the cable..so i know it's not that, as i have the round dash.. but..any ideas?
Thanks everyone! It seems if everything stays working nicely something has to be rebellious and create a problem...
