ramdala Posted February 27, 2012 Share Posted February 27, 2012 Hello All, After reading some opinions on the installation of the "missing Link" I decided to install it. I am not shure if I can fell a big difference or it is psycological but the truck seems more solid specially on curves. I think if you have a SFD, the link frees of the stress of the blocks and of the rear A-arm mounting point...just guessing. Some pics: Link to comment Share on other sites More sharing options...
GRNMACHINE Posted February 28, 2012 Share Posted February 28, 2012 Looks like the design has been changed. I believe the link was one of the cheapest and best mods I have done to the Path (not lifted). Link to comment Share on other sites More sharing options...
Camelfilter Posted February 28, 2012 Share Posted February 28, 2012 I'm curious if folks install this while the front end is jacked up, or not. Perhaps it might cause extra ?torsion or something if it is (or isn't) installed while jacked up? Along a similar idea: My pathfinder seems to ride/corner "nicer" since I installed my sliders. Could be psychological, could be the added weight at lower center G, could be semi-binding of the unibody to subframe, or any combo of previous. Link to comment Share on other sites More sharing options...
ramdala Posted February 28, 2012 Author Share Posted February 28, 2012 Looks like the design has been changed. I believe the link was one of the cheapest and best mods I have done to the Path (not lifted). This is the design that my mechanic did...I have seen differents setups here on npora but at the end I think it is the same. Link to comment Share on other sites More sharing options...
ramdala Posted February 28, 2012 Author Share Posted February 28, 2012 I'm curious if folks install this while the front end is jacked up, or not. Perhaps it might cause extra ?torsion or something if it is (or isn't) installed while jacked up? Along a similar idea: My pathfinder seems to ride/corner "nicer" since I installed my sliders. Could be psychological, could be the added weight at lower center G, could be semi-binding of the unibody to subframe, or any combo of previous. I don't know for sure but I bet that mine was installed with the pathy jacked up... Link to comment Share on other sites More sharing options...
captandy Posted February 29, 2012 Share Posted February 29, 2012 simply easier to reach jacked up..unless your lifted. i think it dosent matter either way.... Link to comment Share on other sites More sharing options...
