statikuz Posted November 22, 2004 Share Posted November 22, 2004 I searched the hell out of this one but I must be missing the one thread that talks about it. Anytime I turn, either direction, I can hear a clunk from the rear end, for instance if I'm driving straight and do some NASCAR-style tire warming it goes clunk clunk clunk clunk each time I turn. I checked around back there, everything seems to be tightened down, its not the tire carrier or stuff bouncing around in the back. Any ideas on what the problem could be or what I should check? Thanks! This is thoroughly annoying... Link to comment Share on other sites More sharing options...
88pathoffroad Posted November 23, 2004 Share Posted November 23, 2004 Swaybar endlink bushings? Shock bushings? Missing coil spring isolator? Link to comment Share on other sites More sharing options...
Guest pathfinder54 Posted November 23, 2004 Share Posted November 23, 2004 r u sure that its coming from the back it almost sound like it the front end have u checked the cv shafts Link to comment Share on other sites More sharing options...
88pathoffroad Posted November 23, 2004 Share Posted November 23, 2004 The CV's don't spin unless the hubs are locked or the t-case is in 4WD... Link to comment Share on other sites More sharing options...
statikuz Posted November 23, 2004 Author Share Posted November 23, 2004 I'm sure that it's coming from the back... Link to comment Share on other sites More sharing options...
Nufy Posted November 23, 2004 Share Posted November 23, 2004 I thought it was all or some of those as well on mine. Turns out I had/have a broken exhaust mount in the backl an dit was llowing it to bang on my running boards. I removed the boards and the knocking went away. Try the simple stuff first. Link to comment Share on other sites More sharing options...
88pathoffroad Posted November 24, 2004 Share Posted November 24, 2004 Yeah. Lie underneath it and have somebody bounce on your back bumper as hard as they can. See what moves. Or if you're strong enough, do bench presses from underneath and bounce it yourself. Link to comment Share on other sites More sharing options...
Adelard of Bath Posted November 27, 2004 Share Posted November 27, 2004 Mine does this...or ~maybe~ a different noise....I always assumed that it was limited slip rear diff making the clunking/groaning noises? Maybe someone before me installed an automatic locker! Admittedly I know very little about lockers/LSD but I used to read a Dodge Ramcharger forum where guys were always talking about installing lockers, and how they made disconcerting noises when you drove on pavement. Link to comment Share on other sites More sharing options...
88pathoffroad Posted November 28, 2004 Share Posted November 28, 2004 A locker will click repeatedly around corners, but not when going over bumps. Link to comment Share on other sites More sharing options...
statikuz Posted December 23, 2004 Author Share Posted December 23, 2004 Alrighty... I thought it might be the body mount bolts cuz it sounded like the lift blocks were sliding around just enough to make noise but that wasn't the case... I had the tire guy crank them down and he said they were already tight. Any other thoughts? It's weird, because if I turn, say, left, it clunks, but then if i continue to turn left, it's quiet until I turn right... almost like something is sliding over, getting stopped, then sliding back the other direction... Link to comment Share on other sites More sharing options...
MaritimeMan Posted December 26, 2004 Share Posted December 26, 2004 That really sounds like the front crossmember. I know you said from the rear, but have you checked them? Here's the link I think you were lookin for. Mr Jim to save the day again Link to comment Share on other sites More sharing options...
statikuz Posted December 26, 2004 Author Share Posted December 26, 2004 Nah, that's not it... I had that problem before but it's definitely coming from the rear. I can be going around a slow turn and it clunks a few times then stops. Link to comment Share on other sites More sharing options...
jj big shoe Posted December 27, 2004 Share Posted December 27, 2004 Just a wild guess, but do you have anything in the rear storage panels? Something could be rolling around in there if so. Link to comment Share on other sites More sharing options...
statikuz Posted December 27, 2004 Author Share Posted December 27, 2004 I thought that might be it too but I checked all around in the back and there's nothing to knock around... I'm sure its coming from the rear axle area or something... Link to comment Share on other sites More sharing options...
88pathoffroad Posted December 27, 2004 Share Posted December 27, 2004 It's a bushing or loose part. Have you gotten under there yet and had someone bounce on the back bumper while you watch? $5 says it's either a swaybar endlink or shock bushing. Link to comment Share on other sites More sharing options...
statikuz Posted December 27, 2004 Author Share Posted December 27, 2004 I think I'm gonna get to installing the rear shocks tomorrow so I'll check those out and report back... Link to comment Share on other sites More sharing options...
