HEADLIGHT HELP
chatch82
HEY GUYS,
So when i turn on my headlights both of the low beams come on and work perfectly but when I switch to high beams the drivers side comes on fine but the passengers side comes on and then after like 5 seconds will dim itself out..............any suggestions. I need to fix this asap to pass inspection!!!!!
yeah, follow (read) the first thread to the end page(s). I bought mine off the ebay. The details are in the thread. Super easy & a great improvement!
Cheers
Edited by lint
The real problem is your headlight switch. Try taking it apart and cleaning the contacts up. The fact that the full current runs through the switch is why it fails, and the relay harness solves that problem.
Pulled the switch yesterday. noticed that one of the contacts which was suppose to be copper in color was totally burnt to a silver color. Cleaned all the contacts and put the switch back in but still no go. Guess I will order a new switch today. :thumbsdown:
