u13turbo Posted May 22, 2011 Share Posted May 22, 2011 Hey guys, got a boost gauge in and connected, just don't know where to wire the light in for it? Also, my new snorkel is 3", should i take the filter box out and chop the old 2" one off and weld on a 3" bit? Link to comment Share on other sites More sharing options...
kiwipete Posted May 22, 2011 Share Posted May 22, 2011 Hey guys, got a boost gauge in and connected, just don't know where to wire the light in for it? Also, my new snorkel is 3", should i take the filter box out and chop the old 2" one off and weld on a 3" bit? The light for the boost gauge is wired to your park lighting circuit, you will have to do some hunting there to find a suitable feed for it. It would be better to go 3" right to the airbox if you can, I used a reducer from my 3" snorkle pipe to the airbox as it was easier. I have some spare flexi hose for the std airbox end if you need it. Link to comment Share on other sites More sharing options...
u13turbo Posted May 22, 2011 Author Share Posted May 22, 2011 The light for the boost gauge is wired to your park lighting circuit, you will have to do some hunting there to find a suitable feed for it. It would be better to go 3" right to the airbox if you can, I used a reducer from my 3" snorkle pipe to the airbox as it was easier. I have some spare flexi hose for the std airbox end if you need it. Cheers for that Pete, I think i will give it ago to go 3" the whole way. As for the park lights, should i be looking around the steering column for a feed? just use a voltmeter to find some voltage when park lights are turned on? Link to comment Share on other sites More sharing options...
kiwipete Posted May 22, 2011 Share Posted May 22, 2011 Cheers for that Pete, I think i will give it ago to go 3" the whole way. As for the park lights, should i be looking around the steering column for a feed? just use a voltmeter to find some voltage when park lights are turned on? Yes there is a park light feed from the switch on the stalk. Link to comment Share on other sites More sharing options...
