snow4me Posted May 2, 2011 Share Posted May 2, 2011 (edited) Finished installing my warn hubs tonight, after having to replace all 6 left front studs from some impact gun happy mechanic used by the previous owner. Turns out my left front ball joint is wasted as well so I need to replace it soon. What is the best method of getting the old one out? By the way, the warn hub upgrade is awesome. Daryl. Edited May 2, 2011 by snow4me Link to comment Share on other sites More sharing options...
PaMountianbiker Posted May 2, 2011 Share Posted May 2, 2011 (edited) Take out the Three bolts that hold it in.They are in the bottom of the a-arm. Edited May 2, 2011 by PaMountianbiker Link to comment Share on other sites More sharing options...
snow4me Posted May 2, 2011 Author Share Posted May 2, 2011 Well, I got that part silly. :-) I had read that the CV is in the way of getting it out and wondered if there was any tricks for wiggling it out of there? Link to comment Share on other sites More sharing options...
fleurys Posted May 2, 2011 Share Posted May 2, 2011 I know the search engine is not the best around, but a user here gave a nice way of finding stuff... in google type this : "ball joint" site:npora.ipbhost.com You will get all the results with the words <ball joints> together... and if you look at the 3rd result, you will get all the info you need... http://www.nissanpathfinders.net/forum/index.php?showtopic=23327 Link to comment Share on other sites More sharing options...
adamzan Posted May 2, 2011 Share Posted May 2, 2011 You just need to undo the snap ring and move the CV enough to wiggle the ball joint out. I found a few good wacks with a pickle fork popped the ball joint out real easy. Link to comment Share on other sites More sharing options...
snow4me Posted May 2, 2011 Author Share Posted May 2, 2011 If you have the snap ring off, are you able to slide the axle shaft inward toward the motor? I had mine off this weekend when I was doing the hubs but didn't try and push it in. Link to comment Share on other sites More sharing options...
adamzan Posted May 2, 2011 Share Posted May 2, 2011 Yeah you can, I kinda pulled up on the brake rotor a bit and jiggled it around and it moved in enough to get the thing out. It helps having a second person so you don't drop the whole thing on your fingers like I did. Link to comment Share on other sites More sharing options...
