Gasoline hydrolock
sewebster
So, seems like my cylinder was so full of fuel that I couldn't start it because the piston just runs into a brick wall of gas. Turned it over by hand and could hear liquid squeezing past the rings instead of gas. Pulled the dipstick and smells like gas. Hooray for injector problems!
Pulled the intake collector off the top... gas was almost up to the top of the lower manifold! It looks like gas is leaking past the o-rings and not leaking out of the injector... which is unfortunate, because I replaced the o-rings a couple weeks ago.
Got it running again. Big difference compared to having a cylinder full of gas :) I wonder if I busted my brand new o2 sensor and cat.
Still some ticking sound from the driver's side... ugh, don't want to do more valve work.
