stock fog lights not working
tsailor21
hi all since i bought thr finder the fog lights have not worked so yester day i was trying to get them working so i replaced the fuse and relay and i still have no powed at the plugin also i see the swich has 4 prongs on it and only 3 wires should there be a fourth wirs on the plug ? thanx tj
no power at what plugin? Are you talking about the plug that goes to the fog lights? Did you check for power inside the fog light where the wire goes to the bulb? Another thing to check is to make sure you have a ground to the light, you could have power but with no ground the test light ( if that is what you are using) still won't light up.
