Build options Reference Sheet w/ links
iatom
Center Link
5 members have voted
  1. 1. Top Center Link
The Goal of this page is to have access in a single page the possible options for your pathfinder/hardbody build. Im trying to keep it simple focusing on problematic or upgrade parts. PM anything you think should be added and i will edit main post. Also links to fourm how to's or kits on things like sas or say alternator swaps.
1986.5-1995
WD21
-Engine Swap
-Engine specific parts swap
*Quest alternator
-Rear Axle
-Front Axle
-Suspension.
-IFS Suspension Kit
*Calmini Steering Kit - $629.95 - NP12451, NP12452
*Deluxe - $915 - SPAC7795PF
-Control Arm Bushing
*Calmini - $49.95 – NP12516
*4x4parts - $49.95 - SPPER50559, SPPE3R5099
-Upper Control Arms
*Calmini - $389.95 – NP12635
*4x4parts - $335 - SPDL0111
-Center Links
*HooHaa - $230+core - OEM
-Idler Arm Brace
*Calmini - $37.95-47.95 - NP12490, NP12490RHD
*4x4parts - $29.95 - SPAC1965b
-HighSpeed Hydraulic Bump Stops
*HighSpeed Hydraulic Bump Stops
-Bumper
R50(1996-2004)
R51(2005-present)
Edited by iatom
what are you gonna do with the truck? If you are running trails, i would get some new 31" tires and armor first, then wheel it and go from there. Just make sure you do everything to prep the truck for off roading first. Yours looks well loved so make sure everything is mechanically sound before you venture off in the bush. also, add a cb to your list. it can save a life, or at the least a long walk ;)
Edited by nige
Great info guys and I agree. Maybe ill put those items under safety. What im really trying to accomplish in this list is a easy reference for Better then OEM parts for problematic or over all better then stock. Allowing some one within one page be able to see all there options and part combos quickly and efficiently.
  • 2 months later...
I have question... I am trying to buy a CALMINI IDLER ARM BRACE. But they have two part number (Part #NP12490 & NP12490RHD) which one is right for my 93 path and or do I need both of these part number? I am trying to buy this b4 I put on my 33 tires. Thanks!!
