Quick accessory question
RustyButTrusty
I'm wondering if the side rails from the 4 door models will work with the earlier 2 door models? I've seen plenty of the 4 door rails, but I've never seen any 2 door rails around at the junkyard. Really it looked like the only difference I could pick up on was just the overall length. Also will this bumper work for an 88 Pathfinder? https://www.4x4parts.com/nissan/arb-winch-mount-bull-bar-p-378.html
I've seen a couple people on here have a bumper similar to this one, not all with the brush guard part, but I was wondering if they make anything like this for my model? Thanks guys!
2 door and 4 door wd21s have the same frame so yea they will interchange (your talkin about side steps, right? Mine are actually off an extended cab [king cab] hardbody). As for that ARB... It bein for a HB makes it a little 'off'. HBs have a factory bodylift (like 1") so on a non-bodylifted wd21 you wold have to modify it to sit a little lower, on a bodylifted one it can either be lived with with a small gap (2" BL) or modified to be correct for a 3" BLed wd21.
Just want to add that the OEM side steps (nerf bars are what we called them) when used on a truck with a body lift, all you have to do is flip the mounting brackets over and it will raise the steps 3" to accommodate the body lift. A friend of mine way back who also had a Hardbody did this with his steps.
we had a wrecked 4 door at my work and we stripped a lot of stuff off of it and my co worker put the nerf bars on my 2 door looks okay i call them my old school sliders ha ha
