two 5 speed swap questions
derrick719
ok so if any one has seem my project on the members ride section. i have done a frame swap and a auto to manual swap (88 frame and trans to a 94 body and engine and drive train). got the body and everything swapped over only prob i have now is the wiring.
is there a write up any where on it? then the other prob i have is the shift boot. the auto had a plate there took it off but the 88s bot and stuff does not fit as its a different shape. any one run into this problem. ill prob end up just cutting a hole in the plate and go with out a center console for now but if there is a better way that would b great
