derrick719 Posted October 8, 2010 Share Posted October 8, 2010 hello every body. im derrick from three hills alberta canada. i picked up a 94 pathfinder le or 700 a month ago or so and it died days after (lost reverse and the frame was rotten dont buy a car at night with out a flash light). so doing a huge rebuild. this is what i am doing. i got another truck a 88 2 door for 250 bucks with a 5 spd and a solid frame. i have pulled the body off both with out any real prob. as of now got the engines out. now going to strip the frame and clean and paint it to protect it from more rust. then put all the 94 bits on it and plop the 94 on top of it and hope i dont drop the body. there will not be any body lifts and stuff now as i need it done before the horrible alberta winters come. so i got a few pics and here they are this is all a one man job so far to the 94 some of the rust the 88 start of the body lift on the 94 (88 done and down on the ground) the little shop i get to use so there it is so far any one have some tips would be great. i also need to figure out the center console dont want to use the big ugly boot. Link to comment Share on other sites More sharing options...
Precise1 Posted October 8, 2010 Share Posted October 8, 2010 Welcome, and wow, that's a big project!! Tips... Tag all electrical connection, flush out the inside of the frame and spray inside with something like denatured fish oil, the rear most chassis bolts on the 94 are larger than the 89 and there are a few other things I'll try to remember, others will chime in though. Which motor are you going to use?? If you are swapping that also, the MPFI system is the superior one... B Link to comment Share on other sites More sharing options...
derrick719 Posted October 8, 2010 Author Share Posted October 8, 2010 ill be using the vg30e and every thing from the 94 but using the 88 trans and transfer case. wont be able to do the side of the frame as i have no way of doing that. if you have some tips for that that would be great Link to comment Share on other sites More sharing options...
teixeira Posted October 10, 2010 Share Posted October 10, 2010 That's a big and great project you have there. One man job?! wow Good luck and be strong. Link to comment Share on other sites More sharing options...
nunya Posted October 10, 2010 Share Posted October 10, 2010 First off welcome! secondly, why pull the 88 apart? Need/prefer the 4 door shell? 2 door shell rotted underneath? fourthly, Center console... Start junkyard scrounging with a tape measure for one you like, a couple people here have had a little luck with the console out of a Jeep Grand Cherokee (I belive there is a pinned writeup on it in the 86.5-89 section here by jj big shoe) have fun with your project, it will be worth it when its togher! Link to comment Share on other sites More sharing options...
Northernpathy Posted October 10, 2010 Share Posted October 10, 2010 Welcome. Yeah that isn't a little project. I bought an 89 hardbody and found out afterwards the frame was very badly rusted and really not worth fixing. In the end I just bought another truck and scrapped the first one. Good luck on the project. I always knew that those Albertans were crazy Link to comment Share on other sites More sharing options...
derrick719 Posted October 10, 2010 Author Share Posted October 10, 2010 ya i bought the 94 first and found the frame was rotten then the trans blew. i got the 88 2 door and the back seats were just floating there there was so much rust in the body and many holes thought out. cant wait to get her done and really hope i dont drop the body im a vancouver island boy actually. ya the crazy albertans are rubbing off on me Link to comment Share on other sites More sharing options...
