Me 1, exhaust studs 0
Well finally the weather has cooled down here and that means taking care of my pathfinder. Been dreading fixing the broken exhaust studs but figured i'd give it a shot. After breaking all the nuts loose (much PB Blaster!) I found that the front 2 were broke flush with the head and the others except one had been replaced with grade 8 studs. I don't have a body lift so space was very tight! Went to work and got a 6inch long 1/8 inch drill bit. Drilled about .2 deep in both broken studs. Used a torx head bit drove into the studs to remove them. They actually came out fairly easy! Once again the pathy is quiet, so hope this helps somebody. Here's some pics of the tools I used.
http://i393.photobucket.com/albums/pp20/Pat1475/IMG_0435.jpg
http://i393.photobucket.com/albums/pp20/Pat1475/IMG_0436.jpg
http://i393.photobucket.com/albums/pp20/Pat1475/IMG_0437.jpg
I'm kinda surprised people are breaking studs, rather than just stripping the heads... which was my problem. Were the original holes supposed to be interference fit to keep them in the head? If so, a previous owner must have tapped the holes on me. I just finished drilling them out and put in bolts instead as it was easier and cheaper. Should hold up fine unless I start taking them off a lot.
dissimilar metals...expansion rates are different and the studs eventually break off dude to heat cycles...its a known problem from hte 80's to the 96 era?
on my way to pickup my pathy from the shop for the same problems. Installed the Pacesetter headers too. 520.00 for the tapping out of 4 bolts and the install.
520! Oh man im glad i did it myself! I couldnt afford that right now. Was that cost for the headers too?
