94beast Posted September 30, 2010 Share Posted September 30, 2010 i have a question my pathfinder has been acting up everytime i would brake on neautral or on gears since its stick shift it would turn off or Also sometimes it wont turn off the rpm wud just drop to 1000 rpm and stay there and sounds like it would want to turn off. Can someone help me out or give advise please? Link to comment Share on other sites More sharing options...
jj big shoe Posted October 1, 2010 Share Posted October 1, 2010 Try the basic tune-up stuff (plugs, wires, filters, etc.) and see where you're at. Link to comment Share on other sites More sharing options...
Precise1 Posted October 1, 2010 Share Posted October 1, 2010 The motor dying might be electrical, and not shutting off (dieseling) is usually tune up related. B Link to comment Share on other sites More sharing options...
unccpathfinder Posted October 1, 2010 Share Posted October 1, 2010 the brake booster runs off of vacuum as well and if your idle is not right (see above posts) it can cause it to stall Link to comment Share on other sites More sharing options...
94beast Posted October 3, 2010 Author Share Posted October 3, 2010 Try the basic tune-up stuff (plugs, wires, filters, etc.) and see where you're at. Thanks for the advise but i took it to two mechanics and the told me it has to do with air flow? one said the intake may be dirty and other said it could be the mass air flow censor im no to sure on what to do and ive done the basic tune up on it Link to comment Share on other sites More sharing options...
94beast Posted October 4, 2010 Author Share Posted October 4, 2010 (edited) The motor dying might be electrical, and not shutting off (dieseling) is usually tune up related. thanks for the advise but i took it to two mechanics and one said it could be that the intake is dirty and other said it could be my mass air flow censor im not to sure on what to do have any other advise? plus i did the basic tune up on it Edited October 4, 2010 by RedPath88 Fixed Quote Tags Link to comment Share on other sites More sharing options...
sewebster Posted October 4, 2010 Share Posted October 4, 2010 Have you checked the engine trouble codes? It could identify a MAF problem for instance... Link to comment Share on other sites More sharing options...
Precise1 Posted October 5, 2010 Share Posted October 5, 2010 There is also a How To thread on cleaning the MAF... B Link to comment Share on other sites More sharing options...
Specv1973 Posted October 6, 2010 Share Posted October 6, 2010 Check all your vacuum lines......especially the one behind the intake manifold going down closest to the firewall. There is a diagram under the hood if you still have yours on which ones to check. You dont want any split ends or cracks. Vacuum leaks can definately cause these problems as I had similar issues and it's an easy fix. Link to comment Share on other sites More sharing options...
5523Pathfinder Posted October 7, 2010 Share Posted October 7, 2010 Did this get figured out? If not, your "not sutting off" issue is probably electrical. Possibly the ignition switch. When you turn your key off, it does not shut off, correct? If thats the case, I would removed the column covers and check for power at the "run" position when turning off your rig. Let us know. Link to comment Share on other sites More sharing options...
