Blow on low gear shifting
tempo
I have automatic transmission on 2002 SE
it sounds like blow BUM i even fil it when shift to or from 2-nd gear
i have 146000 miles - may be uts time to rebuild transmission (this will solve the problem?)
What is 'BUM'?
Have you ever changed the fluid and filter for the transmission? Might be a good idea to do it. Rememeber to check the level when the transmission is warm to get an accurate reading.
Also, proof reading what you write will make answering easier. Thanks.
Jose
Edited by 180sx
