tempo
Everything posted by tempo
2001 pathfinder grinds when moving from 2H to 4L
tempo replied to bro_die's topic in 96-2004 R50 Pathfinders
i shifting this way than it on 2H i pushed it down and when one fast smoth move all the way to 4L same way back Try to push on stick before you take it to 4L -
If i want lift my Pthy only for 2.5" can i still use "usual" plates?
Hi! I will lift my Pathy in special shop (close to summer) But skid plates i want to install by myself I found plates on this link front https://www.4x4parts.com/nissan/pathfinder-front-skid-plate-p-3445.html midle https://www.4x4parts.com/nissan/pathfinder-center-skid-plate-p-3453.html and i will need pay 330$(for both) + 80 $ for shipment ==== Anybody know any other supplier for skids ? may be in Colorado?
Hi! I cant find any theme about oil My Path has 152.000 miles Engine in very good condition - no leaks , compression is like new, and full of power I think it becose all 8 years oil was changing every 3000 miles 9i saw it on carfax records) For right now i used Valvoline Conventional 5W30 May be switch to full sintetic or it doesnt matter with 152.000 miles on engine? Or may be it better to use special oil for high milage engines? Or may be just regular oil with some special additives? Im asking cose i want keep engine in same good condition
For right now i didnt replace bulb cose it light on by itself and its ok already 1 week but i bought 2 bulbs for 7 $ eash in just case it will shut off again...
yes i thougt that problem is connections (bulb come on and off for a while) but mechanic sad its only about bulb
lights was caming on and off for 1 months - now they shutting - i think its importent to know tempreture i will update here --- thanks for links
Hi I need replace RPM and Temprature gauges Bulb its behind dashboard please somebody how i can take dashboard apart? thanks
Hi! I planing lift my Path for 2.5". What suspension kit you can advise?
On 3.5 path no timing belt so pump is gear driven i afraid if pump will brake water will get inside the engine (cose it gear driven) On official maintanance book is nothing about how and when change it So what sings to change it? Noise? what kind of noise/
hi! 2002 , 3.5 , v6 , pathfinder, 150000 miles when i need change water pump if it never changed before? thnks
Hi! How can i apart CD on R50 Pathy? I would like to try fix it or if not so replace Thnks in advance
I use Valvoline 5W30 non-sintetic every 3000 and every 6000 i add BP additives for hi-milage engine my father in law mechanic so he sad that for himilage engine non-sintetic oil is better, i dont know why, but it somthing about density of oil and worn detail of engine
I have automatic transmission on 2002 SE it sounds like blow BUM i even fil it when shift to or from 2-nd gear i have 146000 miles - may be uts time to rebuild transmission (this will solve the problem?)
Hi! What is your year and milage? my 2002 = 145,000 == thks
Hot weather and engine noise and wheel noise
tempo replied to tempo's topic in 96-2004 R50 Pathfinders
You right - when i bit wheel with leg - i hear same noise from brake area i think can i fix this by myself or go to service...its brakes...i dont want screw up with brakes... -
Ok - i dont see nothing broken and when bounce a car - nothing happen But why it happen only on hole - may be this can halp to diagnose problem? ======= what about engine noise? Im very hope its just a vento rotation... -
Hi! I have two questions: 1) Why in hot weather engine noiser than in regular outside condition (noise especially when i on low gears and just start move) Vento may be? In Pathy vanto every time rotate and speed of rotation depend on engine temperature. Do i right? ====== 2)I hear some metallic noise from right wheel when i pass through hole on the road (on speed bumps no noise only if it was hole) ===== Thanks and sorry about my english
check tire - i think this is uneven wear on the height of tire another one thing ask mechanic for check wheel rotation on 65 mph when car on the lift - check how wheels rotate
I agree that ask on Nissan Pathfinder forum "toyota vs nissan" sounds like asking what the best cat or dog in a middle of dog exibition.
