VegasPathfinder Posted August 14, 2010 Share Posted August 14, 2010 I need to replace my wheel studs on my 1993 SE. I would like to get longer studs as well. Where is the best place to buy them at a good price? Link to comment Share on other sites More sharing options...
VegasPathfinder Posted August 15, 2010 Author Share Posted August 15, 2010 Anyone? Link to comment Share on other sites More sharing options...
andreus009 Posted August 17, 2010 Share Posted August 17, 2010 I got a replacement stud at NAPA for the rear. It was the same length as original. Longer studs won't work if you have the acorn style lug nuts. They will bottom out and not hold the wheel correctly. Link to comment Share on other sites More sharing options...
WyKi Posted August 17, 2010 Share Posted August 17, 2010 I got a replacement stud at NAPA for the rear. It was the same length as original. Longer studs won't work if you have the acorn style lug nuts. They will bottom out and not hold the wheel correctly. they wont work with the acorn nuts.. Link to comment Share on other sites More sharing options...
GrimGreg Posted August 18, 2010 Share Posted August 18, 2010 Any part store should sell standard replacements. If you are replacing all, you might have to order them as most places only keep a stock of a dozen or less in the store. Link to comment Share on other sites More sharing options...
VegasPathfinder Posted August 18, 2010 Author Share Posted August 18, 2010 Any idea on what I should pay each? I see them from $1 to $3 a piece. Link to comment Share on other sites More sharing options...
