Battery Help!
Terrano757
Note to everyone reading this thread:
Had the problem sorted out today by taking the car into the auto elec,
heres a little diagnosis/pricing sheet for everyones future reference;
Symptoms:
  • The symptoms mine showed were;
  • Struggling more and more each time to start
  • Eventually not starting at all
  • Once the battery was charged started fine again (Problem not with battery)
  • I then replaced the battery thinking the problem was there, only to have a repeat of events.
Diagnosis:
  • effectively whats happening is something in the alternator is 'draining' the battery while the
    engine is turned OFF
  • However the alternator, whilst driving is still charging (but not at a good rate)
  • Meaning once the car is stopped it is only a matter of time before the battery dies.
Solutions:
  • One cost free, although irritating way you could get around this if it happens to you is
    by disconnecting one of the battery terminals every time you turn the car off, this way the alternator
    charges whilst the car is on, but does not drain when the car is off.
  • The Solution i used was simply to get a brand new, identical alternator. costly, but provides peice of mind
    and 2 years warranty.
Cost:
  • Obviosly for disconnecting a battery terminal the cost is nill.
  • However the cost for a new alternator for a 91 Terrano/Pathy for me was
    $300 and labour was $150 (hence the warranty)
Prevention:
  • Take care of your altinator!!
  • Be carefull through mud & water as either spell trouble for alternators
I hope someone can find this somewhat useful,
I felt like i should contribute something back to the site seeing how much help
i have received off it.
PLEASE CORRECT ME ON ANYTHING I HAVE GOT WRONG
Thanks,
OLD PROBLEM POST BEFORE SOLVED:
umm im having a few battery issues,
i had a 700amp bosche batt, and the other day it was struggling to start a bit, then died completely,
i then charged it up and it worked again for another 2-3 starts before dying again, since then iv been,
-Charging,
-Jump Starting
-and deep cycle charging
it lives then dies again continuously,
Yesterday i purchased a Brand new (only 460amp) battery wholesale price from work,
the engine started fine last night,
however after listening to 5 minutes of music this morning (running Duel Amps) it went completely flat
(just before it died my sterio and CB were flashing on and off, on and off before fully off)
so ive taken the battery out and am getting a 730 amp heavy4x4/commercial battery tomorrow hopefully,
but is there anything i should be worried about??
-Altinator issues??
--Cross wiring?
---Battery Terminals??
Thanks,
Edited by Terrano757
Thanks guys,
however i took it to an auto electrician today for a quick look and he put a multi meter on it and
revved it a bit, and he said the alternator is definitely charging it, just not as much as he would call 'normal'
but still 'charging' he said it might not be charging normal because it was completely dead 5 mins before he
tested it.
maybe the alternator is somehow draining it??
ps: @edicer the belts are fine :(
Thanks guys,
tested it.
What did he say it was charging at for volts? mines formaly around 14 something. The reason i mentioned the belts is becasue mine got bad one time and the alternator one was slipping and i replaced the belt not the altenrator like the mechanic wanted to and itfixed the problem. You could check your grounds for the alternator and battery and make sure they are good.
@edicer; about 12.5V because it was completely flat :(
Symptoms:
Diagnosis:
Solutions:
Cost:
Prevention:
Thanks,
(ps-Will post this at top of thread)
