ahardb0dy Posted May 4, 2010 Share Posted May 4, 2010 Well pulled the 3rd brake light off yesterday, removed the wiper washer nozzle, went at it under the hot water with a pin and finally got what ever was lodged in it out, works great now except the water doesn't come close to touching the rear window, any way to adjust it cause I don't see how it might be done. Thanks Link to comment Share on other sites More sharing options...
kiwipete Posted May 4, 2010 Share Posted May 4, 2010 I'm just guessing here but cant you use a needle to move nozzle jet like you do for the front ones? Link to comment Share on other sites More sharing options...
ahardb0dy Posted May 4, 2010 Author Share Posted May 4, 2010 the front ones have a square hole in between the 2 holes, the rear one does not and does not seem to move, don't know, FSM only shows the front type Link to comment Share on other sites More sharing options...
kiwipete Posted May 4, 2010 Share Posted May 4, 2010 Perhaps you could contact your local Nissan dealer as there is a special tool that is used to adjust the front ones, maybe there is one for the back too? I have only used a needle on the front, haven't had to adjust the rear yet. Link to comment Share on other sites More sharing options...
ahardb0dy Posted May 4, 2010 Author Share Posted May 4, 2010 for the fronts on my sentra I filed down an allen wrench to make i square and it fits right in there. Link to comment Share on other sites More sharing options...
ahardb0dy Posted May 5, 2010 Author Share Posted May 5, 2010 I fixed it for now, I wedged some plastic shims between the top of the nozzle and the housing, good for now. Link to comment Share on other sites More sharing options...
