silverton Posted May 1, 2010 Share Posted May 1, 2010 Sorry for starting a new thread if this had already been covered, I did do some searching and found some stuff, but have another question. I know the fuel gauge and temp gauge have a resistor pack on the backside of the cluster. Basically, what I want to know, is if one works, will the other work just fine? My fuel gauge works perfect, but my coolant gauge barely climbs, even when under load on a freeway hill. I don't have an infrared temp gun to check the inlet/outlet temps on the radiator. Link to comment Share on other sites More sharing options...
GrimGreg Posted May 1, 2010 Share Posted May 1, 2010 The stock gauge out to sit right around the 3/8 point when all is good. Link to comment Share on other sites More sharing options...
silverton Posted May 2, 2010 Author Share Posted May 2, 2010 Then I guess things are not "all good" haha. When I do the timing set I'll have to see what kind of condition the thermostat is in. Link to comment Share on other sites More sharing options...
tmoore4512 Posted May 30, 2010 Share Posted May 30, 2010 Or go aftermarket style on your gauges...My cluster is all jacked up...Temp and tach dance wildly at will...Fuel and Speedo work just fine...(I hope) haha Link to comment Share on other sites More sharing options...
silverton Posted May 30, 2010 Author Share Posted May 30, 2010 Yeah, my tach... "works" I dunno how accurate it is but it will move. on really long drives it must get tired cause it just hangs on the 0. Link to comment Share on other sites More sharing options...
tmoore4512 Posted June 21, 2010 Share Posted June 21, 2010 Mine literally dances all over the place. Drives me nuts, but am not going to spend a chunk of change to get a rebuilt cluster either. Link to comment Share on other sites More sharing options...
Scaramoche Posted June 21, 2010 Share Posted June 21, 2010 hope you find the answer cause mine does the same lol If i only had a schematic for it, then i could probably rebuild it. My spedo doesnt work either, I replaced the spedo cable, and it worked for a couple days, now nothing, i verified the nylon nipple was there, and spring, so guess ill have to look at tranny Link to comment Share on other sites More sharing options...
