Toby Posted March 10, 2010 Share Posted March 10, 2010 My passenger side low-beam is out. Brand new bulb, and high beam is fine. Looked around here and I seen something about it being a headlight/turn signal stalk. I cleaned the connectors at the bulb. They are fine. So I figure it's the stalk. But i wanna get a 'second opinion' i guess. and how much work is associated with replacing said stalk/ Link to comment Share on other sites More sharing options...
GrimGreg Posted March 10, 2010 Share Posted March 10, 2010 My passenger side low-beam is out. Brand new bulb, and high beam is fine. Looked around here and I seen something about it being a headlight/turn signal stalk. I cleaned the connectors at the bulb. They are fine. So I figure it's the stalk. But i wanna get a 'second opinion' i guess. and how much work is associated with replacing said stalk/ If you remove the "stalk" from the column (remove steering cover, then 2 screws hold it on) and look at it, you can see a translucent side that looks like it is clipped onto 4 plastic pins. Pop that cover off and there are your contacts, 5 total; 2 high beam, 2 low beam, 1 running/cabin lights. Link to comment Share on other sites More sharing options...
Toby Posted March 10, 2010 Author Share Posted March 10, 2010 (edited) I'll head out now to check it out. I had to take a nap. Drinking on a week night with friends is a horrible idea Edit: Replaced the stalk, that was the problem. The stalk I took out looks brand new but I dunno. I guess it's shorted inside. Edited March 10, 2010 by Toby Link to comment Share on other sites More sharing options...
