Vq Idles Funny
02silverpathy
My VQ (67K) has been doing something for a while now, however it is starting to get more frequent.
While in drive, stopped, the idle is fine at 650-750 RPM. Truck fully warmed up, etc.
Then for a few turns of the engine it drops to 600-650 and feels like its grinding through the steering wheel and brake pedal...almost lopy as if a cam were installed. Then returns to normal for several moments again.
I would say if I were to be stopped for a total of 5 minutes, in drive, the truck will pull this weird event every 2 minutes??
I have also heard this lopy idle happen while its idling not in drive, but can't tell how it felt as I was not in it.
I have a Chevy buddy that heard this happen and actually asked if I had changed timing or done other work to the engine as the lope for those few seconds makes it sound more like a V8.
Any ideas out there?
  • 1 month later...
Found the problem...super simple.
I had a vacuum leak in my intake piping....that's it. I had also triggered a P0170 lean right bank code, that has yet to some back. The truck had been parked idling for ever in a driveway with the rear end higher than the front by about an " difference, this could have contributed also as the fan was only pulling "x" amount of cool air.
