mickyficky Posted February 19, 2010 Share Posted February 19, 2010 My power steering reservoir has a leak at one of the hoses. It's probably just that the hose is worn out, but I was wondering if anyone has seen this before. It seems like the hose may be clogged. By the way, my steering is fine and the leak is relatively slow (bout 10 drops a day)... Has anyone changed one of these hoses? Is this the in or out hose? I think the system will need to be bled if the hose is changed, will the Haynes manual instructions be acceptable for this or is it harder than it looks? any tips or recommendations would be great. Thanks Link to comment Share on other sites More sharing options...
Precise1 Posted February 19, 2010 Share Posted February 19, 2010 I believe that is the low pressure return line from the PS box. Have you simply tried tightening the clamp a bit (don't over do it, at least at first) to see if that is enough to stop the leak? If the hose is cracked or split, you may be able to simply cut 1" off that end and re-clamp it, otherwise you will have to drain most of the fluid and replace the 12-16" section. Very easy to do, only a screw driver or 10mm (?) wrench needed. If you do drain some of the fluid (looks like yours could use being changed...) all you do to bleed it is fill up the reservoir, start the vehicle and turn the wheels from lock to lock several times. Check the fluid level, fill appropriately and repeat until there is no additional need to refill. B Link to comment Share on other sites More sharing options...
mickyficky Posted February 19, 2010 Author Share Posted February 19, 2010 Thanks Precise, I haven't tried anything, just saw the drops on the ground and snapped the shot this morning with the BB. I'll try it all out... Link to comment Share on other sites More sharing options...
unccpathfinder Posted February 19, 2010 Share Posted February 19, 2010 both of my trucks have done that...i tightened the clamp several times until the hose cracked Link to comment Share on other sites More sharing options...
PATHRIDER Posted February 25, 2010 Share Posted February 25, 2010 My wifes pathy had the very same leak and I replaced the hose a couple of days ago and now her steering is so much better and smoother. I bought some 3/8 hose at auto zone and used different clamps .Filled it with dex3.Its an easy task. 1 hr tops Link to comment Share on other sites More sharing options...
