94pathfinder Posted February 9, 2010 Share Posted February 9, 2010 i believe it's called the drive plate that connects to the flywheel, if so how do you remove the bolts from it to the flywheel so you can fully remove the transmission. Thanks John. Link to comment Share on other sites More sharing options...
KovemaN Posted February 9, 2010 Share Posted February 9, 2010 Pull the starter and access the bolts through that hole. You will need some socket extensions. Be careful not to strip the bolts or you're totally hosed. Link to comment Share on other sites More sharing options...
k9sar Posted February 11, 2010 Share Posted February 11, 2010 what he said. You'll have to manually turn the engine to get to the bolts but they are accessable through the starter hole and even moreso if you remove that lower plate that is also there Link to comment Share on other sites More sharing options...
