wrightfox Posted January 23, 2010 Share Posted January 23, 2010 so the 96 pathys come with a rear tire carrier.. but not after.. well maybe the 97's not sure.. can these be put on a 98 pathfinder? i mean the bodys are exactly alike.. the rear door/hatch has a different place for the license plate but isnt that it.. so can or cant we? Link to comment Share on other sites More sharing options...
Thunderbolt Posted January 23, 2010 Share Posted January 23, 2010 I was wondering that myself, mine is an 01. Wonder what detail would it take to make it work. Link to comment Share on other sites More sharing options...
JUDGE Posted January 23, 2010 Share Posted January 23, 2010 I picked one up from a '96 for my '97 LE and the carrier itself lines up no problem. The issue is the bumper cladding, it needs to be changed to one that had a carrier or it needs to be cut up to allow access for the latch and stricker plate. Link to comment Share on other sites More sharing options...
OfftourRoadie96 Posted January 23, 2010 Share Posted January 23, 2010 I was curious too....I have a 96 that did NOT come with the rear tire carrier....I assume you would need a stronger support mounting surface due to the heavy weight of a FULL SIZE TIRE??? I would think there would be just sheet metal back there if it didn't come stock with the carrier, to try to mount one I think it would just rip the metal? Link to comment Share on other sites More sharing options...
180sx Posted January 23, 2010 Share Posted January 23, 2010 Pathy's that had rear tire carriers were reinforced to support the weight. You would have to weld in some metal where you would mount it. Link to comment Share on other sites More sharing options...
shift220 Posted January 23, 2010 Share Posted January 23, 2010 I'd be willing to bet everything is behind the metal to mount the tire carrier. Considering these are also unibody, there will be a little more beef to begin with. Link to comment Share on other sites More sharing options...
wrightfox Posted January 24, 2010 Author Share Posted January 24, 2010 so all in all this is a simple stock addition for most all of us.. get the carrier with all the parts. and either buy the rear door or just pull all the crap for the carrier of fit. then just put some additional metal on the corner, bolt it up and attach the mounts or replace the hatch? i am going to really consider this.. but.. i could just buy a safari rack and be happy with that too lol.. Link to comment Share on other sites More sharing options...
JUDGE Posted January 26, 2010 Share Posted January 26, 2010 so all in all this is a simple stock addition for most all of us.. get the carrier with all the parts. and either buy the rear door or just pull all the crap for the carrier of fit. then just put some additional metal on the corner, bolt it up and attach the mounts or replace the hatch? i am going to really consider this.. but.. i could just buy a safari rack and be happy with that too lol.. Why replace the hatch? The only thing that brings the hatch into play is the license plate, it will have to be relocated as the carrier will cover it. Your mods will be to the corner and the bumper cladding, none to the hatch. Link to comment Share on other sites More sharing options...
wrightfox Posted January 27, 2010 Author Share Posted January 27, 2010 yeah i just figured the license plate and lights would be in the way was all.. if ot then that makes it that much more simpler.. find a welder for the inside reinforcement and then bolt up and latch. should be easy and junkyard find hopefully cheap!! Link to comment Share on other sites More sharing options...
Fukinitupagain Posted January 27, 2010 Share Posted January 27, 2010 just build a new rear bumper with a tire carrier. Easy. Problem solved & you don't have to worry about reinforcing the bodypanel for a stock carrier Link to comment Share on other sites More sharing options...
wrightfox Posted January 27, 2010 Author Share Posted January 27, 2010 well if i get a new rear bumper.. i want a tube one. and i think it will cost less to do it this way then to do it with a carrier.. just a thought. Link to comment Share on other sites More sharing options...
