Nismojunky Posted September 13, 2009 Share Posted September 13, 2009 i have been thinking of doing a sas for a wile now, i know im going to do a trailing arm set up with coils i was wondering if i could use the same set up as the rear axle in these pathfinders, do u think it would work? Link to comment Share on other sites More sharing options...
packie88 Posted September 14, 2009 Share Posted September 14, 2009 it would workbut youll lose articulation compared to a 3 link w/ panhard or triangulated 4 link. the reason being the link ends will bind under articulation but youll gain some back depending on the links end. the 5 link screads the load across more of the frame then say a radius arm. if you gonna put the design and effort to do a coil set up i would do it toward a 3 link with panhard for the front. 4 link front ends have steeering issues and would probably have to go to hydro steer because the tri 4 link would casue major bumpsteer....IT all also depends on what your using it for. are u planning on street driving it Link to comment Share on other sites More sharing options...
Nismojunky Posted September 15, 2009 Author Share Posted September 15, 2009 yes im planning on street driving Link to comment Share on other sites More sharing options...
packie88 Posted September 15, 2009 Share Posted September 15, 2009 then i would do a 3 link wiht panhard or radius arm Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted September 17, 2009 Share Posted September 17, 2009 spend the extra work and go 3 link. works awesome offroad! www.nissannut.com Link to comment Share on other sites More sharing options...
