flooding problem revisited
carwilef7
I Posted about an intermittent flooding problem a few days ago. Here's an update:
From sitting for a couple of hours, I went to the store a mile away, left the truck running for about 3 minutes, then rolled down the street to the carwash and shut it off. Washed the truck (4 min., maybe), and it flooded when I turned the key. Waited ten for it to clear out and drove back home.
Waited about 4 minutes and it started up perfectly - no gas smell. Went out an hour later, had a beer with friends, hung out for an hour. Started fine, drove home (6 miles - it was in the normal temp range). Waited 15 minutes and tried to start and it flooded again.
Waited another 10 min to clear it., then for the hell of it I pulled a plug wire and stuck a screwdriver in the end with the shaft near the manifold in order to check spark while cranking. Truck started right up on 5 cylinders, but there was a yellow arc instead of the blue I expected.
Shut it off, re-installed the plug wire, restarted and let it run a cpl minutes and shut it off. Waited 5 minutes and it started fine. And again five minutes later, and yet again, five minutes after that.
Seems to me that either something causes all the injectors to dump a @#$%load of fuel at one random key turn, or there's a glitch in the ignition system that allows ok-to-mediocre spark sometimes, and none at others.
Any ideas?
