Bolts
Runnerman
Home Depot does not have any of the Bolts I need. Nor does Rona or any of the other local Home Reno stores :blink: .
Ya, tried a whole lot of them then after I found a local shop I think they wanted one of my legs as a down payment for some bolts. Ended up being cheaper to order from Remco even know they are located out of Country and after exchanging our mighty canadian dollar :oops: .
:beer:
I had the same problem trying to find a 10 mm bolt 100mm long. I was about to order on line when I was told about an old hardware store. This place has been around for 100 years and down in their basement they had just about every metric blot you could think of. The also had metric threaded rod. The price was not too bad. Both grade 8.8 and grade 10. P...
I needed some metric head bolts for a honda that I had so I went to the local u-pull-it junkyard and found a parted engine. .10 each for the bolts. 1.59 for the box of band-aids I needed for my knuckles after tearing apart an old engine.
Did you get your bolts yet?
Here is a couple Canadian suppliers for your reference.
http://www.brafasco.com/home.htm
http://www.boltandnutsupply.com/
Thanks for the links as this company carry's the bolts I need, the other does not.
Also at a fraction of the cost and cheaper shipping then getting from the States.
Thanks Again :clap:
:beer:
