93 SE "build thread"
Tosh
so i have a question
i heard some rattling up front today when i came home. i was on this trail and the only time i heard it was when i would hit a rut. i went under it and looked and all of the bearings look good still but the left side of the front sway bar seemed loose. i just didn't know if mild flexing in ruts could damage the sway bar
You won't find an easier set of bushings to replace. The sway bar is just held on by a rod/long bolt, sleeve, washers, and rubber bushings. A 12mm or a 14mm deep socket and an equal size wrench or another socket is all you need to replace those. They just slide on and off. Take a good look at it, you'll figure it out. :aok:
