Spring/Strut Compressor
GoPathyGo
The search didn't reveal anything dedicated to this so thought I'd post a new topic.
What type of spring/strut compressor do you use or recommend ? I have tried the Sears Craftsman and the Autozone models. The Sears Craftsman failed and the assembly blew apart. I will be returning them and writing to the Consumer Safety Products Commission. The Autozone one only works if you don't have to install a strut INSIDE the spring or you use 2 of them. Kinda useless from my perspective.
This is the Sears Craftsman one that failed on me. I have seen the same design all over the web.
http://www.sears.com/shc/s/p_10153_12605_0...ring+compressor
After the failure and after seeing a much more robust hydraulic wall-mounted screw-type compressor at the local NTB, I'm beginning to wonder if the 2 rod design above can work safely and reliably.
The hydraulic ones seem to run hundreds of dollars, though. The only vaguely affordable thing I found was this. Seems reasonable given that, around here, a suspension swap can run a few hundred bucks with no guarantee it'll be done right...
http://www.jackstoolshed.com/index/page/pr...ring+Compressor
Thoughts ? Ideas ? Recommendations ?
from sucks I have rented a spring compressor; a 2 arm top and bottom unit that goes thru the center of the spring.
and a strut compressor which was 2 one arm units units in a case that went on either side of the spring.
Other than the physcial limitations such as the treads reaching the frame, axle, body or spidle I had no issues. and those were as simple as just repositioning the tool and trying again.
I belive schucks rents out powerbuilt tools and I can say the only unsafe moment was when I used the 1 spring compressor on the outside of a jeep coil but that was me being unsafe not the tool.
In genereal, I have never had an issue with a powerbuilt tool. tradespro on the other hand.....(I think I was born with a curse that makes trades pro break when I touch it)
All been said here...
http://npora.ipbhost.com//index.php?showto...ing+compressors
Sounds like operator error to me GPG. :shrug:
No way, man. The strut assembly was off the car and the compressors were only compressing 'em so you can get the strut out. I tried em a 2nd time after the first one blew apart, this time with a friend overseeing the process. We both agreed these things were unsafe.
Here's how the process went. Check out the compressor this guy's using. I think that's a Troy 1-ton.
http://www.bimmerboard.com/forums/posts/574720
Found that 2-ton thing for $110 on eBay... Considering I still have to do the rears on the car and am thinking about switching to OME springs for the Pathy (see my build thread) might be a good deal. I really don't want to pay $300-$400 to a local shop to do the whole thing...
I've used mine a dozen times on VWs, Pathys and Hondas. I never had any problem, did you read the instructions? :D
5 times. Didn't want it to blow apart. Fat lot of good that did me.
Think I'm gonna go with that $110 hydraulic one. Will pay for itself on the first strut and I can always rent it out.
The ones I used were different. Did you look at the link??
Yeah, the thread showed Harbor Freight ones with much better clamps than the Sears Cr*pman ones. Having been burned (in this case, literally) with the 2-rod setup I'm very tempted to go with that $110 hydraulic one because its clamping system provides a little bit more room for error and there's a nice thick bar between the spring and the operator. :)
Of course, the Troy 1-ton has a remote that allows you to stand away from everything. But its clamps can only go up to 7" od springs and it's $50 more expensive. I don't know whether I will need 10" od springs but I always need $50. :)
http://www.amazon.com/Troy-ME4098-Hydrauli...r/dp/B000BMJX46
