'95 4x4 Pathfinder - Several Questions
  • Replies 53
  • Created
  • Last Reply
Top Posters In This Topic
My truck has the same ground I will look tommaro to see if its vital.And I wish my frame looked like that.
I finally got out my flashlight and followed that flexible metal grounding strap.
The other end is screwed onto the body !
How strange !
The body is bolted to the frame.
Why connect the two with a flexible metal strap ?
Seems redundant to the N'th degree !
Maybe Nissan was anticipating their rust-out problem.......
DoctorBill
How strange !
DoctorBill
Actually, the body has rubber spacers/pads in between the body mounts and the body, the only way they would connect is if one of the bolts touched an edge, because even the captives don't direclty touch both, unless inside the pilot hole they touch side...
Probably just to make the frame and body both groundable...
I am now wondering if this lack of a working Body - Frame ground isn't the reason my Tachometer
goes nuts most of the time ? Is the Tach grounded to the Body inside the cab and thus not getting
a good signal or a screwie signal ?
A thought.
DoctorBill
