joshellis Posted June 17, 2009 Share Posted June 17, 2009 Hi The MT in my Pathy is 177000 miles strong, running 5.1L GL-4. No major whines, but definitely some signs of normal wear. Synchros are in great condition given the previous owner probably used GL5 fluid and only 4L. Anyway it has a tendency to jump out of 3rd upon deceleration at speeds below 25mph. Is this irreversible wear? I suspect it will keep on soldiering for at least another 177000 miles, my previous diesel Terrano did the same, and that transmission had spent most of its life under water! Any advice? Thanks Link to comment Share on other sites More sharing options...
Kingman Posted June 17, 2009 Share Posted June 17, 2009 Any advice? Drive it till it drops Link to comment Share on other sites More sharing options...
Alkorahil Posted June 18, 2009 Share Posted June 18, 2009 HiThe MT in my Pathy is 177000 miles strong, running 5.1L GL-4. No major whines, but definitely some signs of normal wear. Synchros are in great condition given the previous owner probably used GL5 fluid and only 4L. Anyway it has a tendency to jump out of 3rd upon deceleration at speeds below 25mph. Is this irreversible wear? I suspect it will keep on soldiering for at least another 177000 miles, my previous diesel Terrano did the same, and that transmission had spent most of its life under water! Any advice? Thanks Your linkage needs adjusting or the gear syncronyzer between 3rd and 2nd is worn out. Either way it will probalby get worse with time. Link to comment Share on other sites More sharing options...
joshellis Posted June 19, 2009 Author Share Posted June 19, 2009 Thanks Alkorahil. By linkage do you mean shift linkage, or something inside the case? Sorry about the rookie questions... Josh Link to comment Share on other sites More sharing options...
Precise1 Posted June 25, 2009 Share Posted June 25, 2009 Any advice? Thanks Yeah, buy the MT out of my old Pathy, it only has 132k miles and no issues... B Link to comment Share on other sites More sharing options...
