schro Posted June 13, 2009 Share Posted June 13, 2009 I have an intermittent problem with my '95 pathfinder not starting. I have replaced the starter solenoid after which it worked fine with no symptoms for about 2 weeks. Then it died again, and I had to bump start it to get home. I went to the auto wrecker and pulled a starter from another '95 and did the swap, after which it worked fine for a week and now has just died again. Methinks that the problem is not with the starter, but the intermittent nature of the problem is making it difficult to diagnose. When I turn the wipers on they run at a good speed, and resting battery voltage is 12.6V (the battery is only a year old, good quality Interstate battery) so I don't think that the problem is with the battery or charging system. Does not start with jumper cables either. I'm thinking it must be a computer/sensor switch issue. Maybe a faulty safety interlock switch or maybe ignition switch or relay somewhere... Any ideas? Link to comment Share on other sites More sharing options...
Precise1 Posted June 14, 2009 Share Posted June 14, 2009 (edited) Definitely sounds like wiring... Check the... Let me just link you to two similiar threads... B http://www.nissanpathfinders.net/forum/index.php?showtopic=22821 http://www.nissanpathfinders.net/forum/index.php?showtopic=22835 Edited June 14, 2009 by Precise1 Links Link to comment Share on other sites More sharing options...
nunya Posted June 14, 2009 Share Posted June 14, 2009 Noticing a pattern of them all being 5 speeds with issues... Link to comment Share on other sites More sharing options...
k9sar Posted June 14, 2009 Share Posted June 14, 2009 seem to be a bunch lately. Link to comment Share on other sites More sharing options...
Precise1 Posted June 14, 2009 Share Posted June 14, 2009 Good point... My old 95xe manual was just starting to crank very slowly/nothing just days before I parked it so I never tried to figure out the issue. Assumed it was the starter (battery was fine) but didn't care... B Link to comment Share on other sites More sharing options...
