MadManMike Posted May 31, 2009 Share Posted May 31, 2009 Hey guys, So my trip odometer and low gas light quit working, so I figured I would remove the instrument cluster and make sure the wires were good and tight. I know how to remove the instrument trim on a pre-1994 pathfinder, but I can't figure out what I am doing with my 1995. I removed the top 2 screws but can't figure out where to go from here, I am afraid of breaking the trim. Any suggestions? -Mike Link to comment Share on other sites More sharing options...
unccpathfinder Posted June 1, 2009 Share Posted June 1, 2009 remove the lower dash...2 screws in the lower RH and LH corners then there are 2 more screws on the black bezel then there are 4 screws on the cluster then 4 connectors to remove on the back side that should do it for ya Link to comment Share on other sites More sharing options...
Precise1 Posted June 1, 2009 Share Posted June 1, 2009 X2 It might be easier if you remove the top steering column cover but be careful, the screw mount points are not robust. B Link to comment Share on other sites More sharing options...
PitBullGirl23 Posted February 25, 2014 Share Posted February 25, 2014 Thanks! This helped me clean my contacts. Link to comment Share on other sites More sharing options...
