KP3S Posted May 22, 2009 Share Posted May 22, 2009 My '92 XE Pathy has this rocker switch bad, what this switch do? Link to comment Share on other sites More sharing options...
88pathoffroad Posted May 23, 2009 Share Posted May 23, 2009 The E-AT switch changes the way the transmission shifts. When it is set to Auto, (or off?) it shifts normally. When it is set to the other position the transmission will down-shift sooner, hold gears for longer and help get you moving faster. For best fuel economy the switch should be set to off or Auto. OK, someone else help me out here. I don't have a 4-door and the 2-door version of the E-AT switch is a "Power" button on the shifter. It does the same thing but it's labeled "Power Shift" and the switch is either "Auto" or "Power". Is the E-AT switch on the 90-95's labeled Power and Auto too? Link to comment Share on other sites More sharing options...
adamzan Posted May 23, 2009 Share Posted May 23, 2009 Yes it says power and auto Link to comment Share on other sites More sharing options...
KP3S Posted May 23, 2009 Author Share Posted May 23, 2009 (edited) Ok, thanks for the reply, now I need to get that switch that is not working on my Pathy. Edited May 23, 2009 by KP3S Link to comment Share on other sites More sharing options...
