k9sar Posted April 29, 2009 Share Posted April 29, 2009 I need to remove the tube that the oil dipstick goes down through. Anyone know how they come out (if at all?) Close inspection shows a half-washer looking thing where it goes into the block but it does not appear to be a snap-ring or similar. On my caravan, the holder just slips into a home but there is a bracket that bolts onto it to hold it. Nothing like that here. thoughts? Link to comment Share on other sites More sharing options...
RedPath88 Posted April 30, 2009 Share Posted April 30, 2009 Looks like it just presses in (remember the bolt near the top) with locktite to seal it?? http://stan.x2o.net/Hardbody/ntb96065.pdf - Page 9 And just an FYI, when removing the oil pan http://maxima.theowensfamily.com/tsb/NTB94-089.pdf Link to comment Share on other sites More sharing options...
unccpathfinder Posted April 30, 2009 Share Posted April 30, 2009 yep all the nissan ones i've seen just pull out Link to comment Share on other sites More sharing options...
k9sar Posted April 30, 2009 Author Share Posted April 30, 2009 so the damned thing is just glued in? great. Link to comment Share on other sites More sharing options...
unccpathfinder Posted April 30, 2009 Share Posted April 30, 2009 i dont even think its glued in I think its just an interference fit Link to comment Share on other sites More sharing options...
k9sar Posted April 30, 2009 Author Share Posted April 30, 2009 I wanted to be graceful in removing it (it IS on a spare engine) but if I need to just rip the stupid thing out, I will. Link to comment Share on other sites More sharing options...
unccpathfinder Posted April 30, 2009 Share Posted April 30, 2009 yea there should be that 1 bolt that redpath mentioned and I just took a thin flat head between the base of the tube and the block and tapped it in then just gently jiggled the tube and pulled and it came right out if you mess it up i my have an extra that I could ship for the cost of shipping Link to comment Share on other sites More sharing options...
k9sar Posted April 30, 2009 Author Share Posted April 30, 2009 yea there should be that 1 bolt that redpath mentioned and I just took a thin flat head between the base of the tube and the block and tapped it in then just gently jiggled the tube and pulled and it came right out if you mess it up i my have an extra that I could ship for the cost of shipping there's no bolt that I can see. The tube just comes out of the block and hangs out there in mid air. Link to comment Share on other sites More sharing options...
unccpathfinder Posted April 30, 2009 Share Posted April 30, 2009 yea thats how my 95 is...my 87 I think had a 10mm...so there you go...just pull it out Link to comment Share on other sites More sharing options...
