2" or 3" lift?
EmptyV
So I've got an 01 QX4 2WD no bumper/winch. I've got the OME HD setup on it's way and was thinking because of the lack of front differential that the front will sit level with the back without a strut spacer. So is installing strut spacers and doing the bump stop trick for the rear springs to achieve a 3" lift a good idea or not? What is the disadvantage of a 3" lift over a 2"?
Thanks!
Billy
no offense alexr50, but empty v, do you really wanna take suspension advice from someone on stock suspension???
i saw go the extra mile and do 3" i just did the 2" and i wish i had more....esp if i was 2wd i would have been on spacers by now
i knew it was somethin like that :D im sure once you get those coils on you'll be wanting to go higher too. its an addiction man
Agreed, it is a huge addiction...It was so tempting to get the SFD when I had the chance.
So would you recommend doing the double bumpstop trick for the rear? I don't know of any other way to get the rear up 3".
Billy
FUELER, i'm only offended that you didn't get my name right. ;):D
:rofl:
The only sh*tty part is the waiting... I lost count, to be honest. :lol:
couldn't you use rubber coil spacers that you put in between the coils ? http://www.sfxperformance.com/parts/MRG1287-X2.htm
Nice. Those are definitely a good idea! :aok:
Dude! Thanks for the link, I just ordered a set. Now the last components I need are my rear coils which are on order and the NX4 spacers and I should have a 3" lift. So next question is will 33's fit or should I stick with 32's?
Billy
Billy
I'd say 32's would be ideal for clearance up front. Not sure about 33's but there's a first time for everything. :lol:
