tuttlej Posted March 29, 2009 Share Posted March 29, 2009 Hi Im a new member from utah and dont no how to use a computer so Im probably puting things in the wrong places but any way I just got a 1989 pathfinder 5 speed dont no any thing about it as far as gear ratio in axles or T-cases so I have some questions hope some one can help first can any one tell me what my gear ratios are and can i double my transfer case is there a better t-case that will bolt to my tranny please help Link to comment Share on other sites More sharing options...
beavis0076 Posted March 30, 2009 Share Posted March 30, 2009 Can't help ya there.... but welcome! Link to comment Share on other sites More sharing options...
unccpathfinder Posted March 30, 2009 Share Posted March 30, 2009 welcome...I know there are 2 different ratio's 1 for the MT and one for the AT...SteevO from RuggedRocksOffroad.com put an atlas in his pathy and I think in 4-lo his ratio is 10:1. That is a pretty extensive swap I think but you should be able to get some "crawler" gears. There is a search function that is pretty tough to use but it gets easier with practice I think the 2 rear axle ratios in the WD21 are usually but not always 4.63 gear ratio for the auto and the mans are only 4.37 Keep up the good work with the computer skills. you managed to get registered and start in the right area and found one of the best sources of information for your pathfinder Link to comment Share on other sites More sharing options...
Pezzy Posted March 30, 2009 Share Posted March 30, 2009 Keep up the good work with the computer skills. you managed to get registered and start in the right area and found one of the best sources of information for your pathfinder Exactly my thought!! Welcome to NPORA! Link to comment Share on other sites More sharing options...
Precise1 Posted March 30, 2009 Share Posted March 30, 2009 Welcome Tuttle, you are doing fine so far but let us know if you need some assistance with the forum functions. I think the 2 rear axle ratios in the WD21 are usually but not always 4.63 gear ratio for the auto and the mans are only 4.37 Not necessarily. I have 2 95XEs. 1 has manual tranny, 31" tires (stock I believe), 4.63 gears. 1 has automagic tranny, 235/75/15 tires (29", stock I believe), 4.63 gears. I could never determine the rhyme or reason. Tuttle, click on the link below, it will open up a new window and topic thread on the two gear ratios and where to locate the plaque that will tell you what you have... http://npora.ipbhost.com//index.php?&s...e=show&st=0 B Oh, I'll let the more experienced go into transfer cases... Link to comment Share on other sites More sharing options...
Slick Posted March 31, 2009 Share Posted March 31, 2009 hello and welcome to the family! Link to comment Share on other sites More sharing options...
Nytrosfinder Posted March 31, 2009 Share Posted March 31, 2009 Welcome friend.... Let us know if you need anything.... bunch of nice people on here... we are glad to help you out in any way we can... Link to comment Share on other sites More sharing options...
colbywan Posted April 1, 2009 Share Posted April 1, 2009 Welcome aboard there, I too live in Utah! -Colby Link to comment Share on other sites More sharing options...
unccpathfinder Posted April 2, 2009 Share Posted April 2, 2009 Not necessarily. I have 2 95XEs. thats y i had my disclaimer in there...a good way to figure it out is to put the truck in N and jack up one the rear tires mark a spot on the ground and on the tire (tape would work fine on this and then do the same for the drive shaft on the axle...have someone rotate the wheel and count how many rotations you get out of the pinion...its pretty obvious between 1/3 and 2/3s so that will let you know if its the .3 or .6 do they placard these on the door jams? Link to comment Share on other sites More sharing options...
Precise1 Posted April 2, 2009 Share Posted April 2, 2009 Welcome Tuttle, you are doing fine so far but let us know if you need some assistance with the forum functions.Not necessarily. I have 2 95XEs. 1 has manual tranny, 31" tires (stock I believe), 4.63 gears. 1 has automagic tranny, 235/75/15 tires (29", stock I believe), 4.63 gears. I could never determine the rhyme or reason. Tuttle, click on the link below, it will open up a new window and topic thread on the two gear ratios and where to locate the plaque that will tell you what you have... http://npora.ipbhost.com//index.php?&s...e=show&st=0 B Oh, I'll let the more experienced go into transfer cases... The link above will show you where the plaque is... B Link to comment Share on other sites More sharing options...
