DaveS Posted February 2, 2009 Share Posted February 2, 2009 my dash lights go out every now and then, the headlights always stay on. they seem to go when i hit bumps. i can usually get them back on by turning the headlights off and on a couple of times. they have never come back on by them selves, but then i have never given them much time to do so. is this problem caused by the headlight switch (the part that rotates to trun the lights on and off is loose). i have been looking at the service manual but have not been able to figure out how the lights are wired. if any one could shed some light on the subject it would be greatly appreciated. and wire colors in the dash for headlights high and low and dash lights would be great. Thanks Dave Link to comment Share on other sites More sharing options...
94extreme Posted February 2, 2009 Share Posted February 2, 2009 could v3ry well be the switch. keep looking at the manual; the wiring diagrams are good. Link to comment Share on other sites More sharing options...
edicer2 Posted February 2, 2009 Share Posted February 2, 2009 i bet its the switch it sounds like a short. if u need one pm me Link to comment Share on other sites More sharing options...
GrimGreg Posted February 2, 2009 Share Posted February 2, 2009 Probably need to clean the contacts in the switch. Link to comment Share on other sites More sharing options...
DaveS Posted February 2, 2009 Author Share Posted February 2, 2009 Probably need to clean the contacts in the switch. How would i go about cleaning the contacts on that switch i cant see away to take it apart. Link to comment Share on other sites More sharing options...
edicer2 Posted February 2, 2009 Share Posted February 2, 2009 check your dimmer switch to make sure it works good and also check the back of the cluster to make sure all the plugs are tight on there. Link to comment Share on other sites More sharing options...
GrimGreg Posted February 2, 2009 Share Posted February 2, 2009 How would i go about cleaning the contacts on that switch i cant see away to take it apart. I just explained it not to long ago in this post: http://npora.ipbhost.com//index.php?showto...amp;hl=contacts Link to comment Share on other sites More sharing options...
edicer2 Posted February 2, 2009 Share Posted February 2, 2009 sounds like the dimmer switch or the plug in the back of the cluster is loose IMO but if cleaning those is easier then try that first. Im still pretty sure the headlights would flicker if it was the light switch. the dimmer and the back of the cluster is probably easier to check first since its 9 screws total to check them both out. Link to comment Share on other sites More sharing options...
DaveS Posted February 2, 2009 Author Share Posted February 2, 2009 i checked the plugs on the back of the guages they seem to be tight and the dimmer seems to work. but i tried to make the lights cut out last night and coundn't get them to go out. so I'm not sure if it is just the guage lights or if the lights by the heator controls go out to. or if the tail lights and the marker lights go out to. but when the do go out turning the switch on and off a fiew times seems to make them come back on. even when I'm not moving. i did notice that there are 2 taps on the wires coming from the the turn signal/ headlight switch. and i have still been unable to find the pins and colors of the wires coming from that switch go to if anyone can point me to where i would find this in the manual that would be great. Link to comment Share on other sites More sharing options...
