Engine Swap...
dududuckling
Guys, this is just some random question that got on my mind...
I have a 2000 Pathfinder SE with 3.3L V6... Is engine swap with 4.0L V6 (2005 and up) or 3.5 L V6 (2001-2004) possible?
If yes, is it worth the time and money... or should I get a used 2005 Pathy instead?
And what about installing a turbo or supercharger? I think this will drastically empty my fuel tank within seconds...
I asked this because I like the way my Pathfinder behaves on the street and its reliability... but I feel the 3.3L V6 engine is seriously underpowered... and as compared with the later Pathfinders, the later engines offer more horsepower for approximately the same gas mileage.
Thanks...
Supercharging the 3.3 wouldn't be too hard, swaping in a 3.5 would be a lot more custom & time consuming & swaping the 4.0 would be hella crazy (custom otor mounts, tranny swap, the pushback of the firewall, etc, etc). This summer I am gonna try to use a super charger from an Xterra or Frontier as long as I don't take summer courses.
If its a major concern for you just get a 2001+ R50 with the 3.5: I don't see the point in getting the R51 with the 4.0 for more power because it wieghs a lot more so there's a balance there - if you go with an R51 get the V8.
Agreed! The VK56DE is a nasty engine, especially in a R51 (lighter than the Armada or Titan). :aok:
As for the me, I'm trying to locate a VG33ER to swap into my R50. Then all that needs to be done is a custom hood modification. :jig:
The hood mod shouldn't be that difficult (that'll be the least of your concerns)
I'm looking forward to fabbing up a rad hood! :aok:
I'm just hoping I can find a donor Xterra before long so I can figure out all the details to make this swap go as smoothly as possible. For the moment, the R50's my only ride... :doh:
I wonder how extensive the wiring swap is gonna be on that? I remeber when i swaped a SR20 into my friends 240. No idea how bad it was gonnna be, spent the next 2 weeks figuring the damn thing out. (Then we found out we could just buy the modded harness!). Makes me wonder...
Took us 5 days to swap a S13 SR20 into his 240SX... ended up being easier than we hoped. I have total confidence in getting this swap done. :aok:
It won't be that difficult because its the same engine to begin with. A couple of mounts are different & a few things are located in differemt places but as long as you get the wiring harness with the engine it should be about as easy as swaping in the VG33E & fabbing up some mounts for other things.
Music to my ears yo! :jig:
cut it off and fab up a front clip, then you can put whatever you want - VK56, LS2/LQ9/etc, ;)
LOL :aok:
Thought of that but my primary option (realistically & financially) is for now the VG33ER... If I can manage to get lucky with locating a QD32ETi then things may change.
