Which is the fuel pump feed / return
Ruiner
Need to know which hose is the high pressure feed, and which is the return... My line burst open, and each time I replace the section a new one busts / leaks. So I'm going to replace the entire thing temporarily with high pressure fuel hose to eliminate the rusty section...
Which is the fuel feed on the pump? I've searched for an hour, but the results turned up nothing.
EDIT: Figured out, see post 3.
Edited by Ruiner
The one that keeps bursting open is the fuel feed. The return will be under considerably less pressure.
Wow. Thanks for that helpful tip.
I figured which line was the feed. On top of the pump if you are looking at the bulkhead from in the hatch, it is the closest to the front of the car...
*Just in case anyone else searches and needs to know this.
