zack1978 Posted November 13, 2008 Share Posted November 13, 2008 I think the alternator is on it's way out on my 1995 SE-V6, but the strange thing is that it works when it wants to at this point. I did have the tell tale dash lights go on once or twice, but that is not a constant. The bigger issue is that the dash lights get brighter and dim at random times, is that indicitave of the alternator as well? Thanks, Zack Link to comment Share on other sites More sharing options...
Simon Posted November 13, 2008 Share Posted November 13, 2008 Check your belt. It could be too loose and slipping. Link to comment Share on other sites More sharing options...
5523Pathfinder Posted November 13, 2008 Share Posted November 13, 2008 The alternator uses a internal voltage reguator. I would removed the alternator and take it down to your local Parts store and see if they can test it for you. Usually thats free. Double check all your connections on the Alt as well as your battery and the ground on the engine. Link to comment Share on other sites More sharing options...
Harvey Posted November 17, 2008 Share Posted November 17, 2008 A good way to test your alternator is to do the following with your multimeter: Test battery current with vehicle off. Test battery current with vehicle on, no ancilliaries, just idleing Test alternator current with vehicle on, no ancilliaries, just idleing. Test battery again with all electrical items on, running at approx 1/3 - 1/2 revs Test alternator again with all electrical items on, running at approx. 1/3 - 1/2 revs. By doing the above, you will see if the alternator is really charging the battery or not, both at low revs/stress and higher revs/stress. We've done this on all my vehicles when we've suspected the alternator and it's turned out to be an accurate test. Link to comment Share on other sites More sharing options...
edicer2 Posted November 17, 2008 Share Posted November 17, 2008 I had the same problem with my alternator it would do that but would charge enough so the battery wouldnt die but once i put a system in mine the light would come on alot and the battery would die. SO i just had to change my belts and it worked great ever sense! Link to comment Share on other sites More sharing options...
