pulxar Posted September 14, 2008 Share Posted September 14, 2008 Hello all, this is my first post since finding you guys. I have a 94 SE that is basically stock. The alarm is apparently dead, though I get varying voltages from 1 to 12 volts depending on the wire going into the system. The security switch on the console only reads just about a volt or nothing depending on the position of the switch. I think there is a short somewhere but without a wiring diagram I am stuck. I have been fixing up my pathy for about a year now and it is getting there. If any of you know where I can get a wiring diagram for the alarm system or have any other advice it'd be greatly appreciated. It is not in the FSM which I found at phatg20.net, a great site if you haven't checked it out. Link to comment Share on other sites More sharing options...
FullThrottle Posted September 14, 2008 Share Posted September 14, 2008 You might be able to locate it in the manual. You can download them from.... http://www.phatg20.net/component/option,co...c,select/id,31/ Cheers Ants Link to comment Share on other sites More sharing options...
pulxar Posted September 15, 2008 Author Share Posted September 15, 2008 You might be able to locate it in the manual. You can download them from.... http://www.phatg20.net/component/option,co...c,select/id,31/ Cheers Ants Good thought, that was the first place I checked but no luck. Link to comment Share on other sites More sharing options...
5523Pathfinder Posted September 15, 2008 Share Posted September 15, 2008 The wiring diagram and wire colors are in a TSB. The number is NTB93-036. I know its not much help, but you may be able to find it. Link to comment Share on other sites More sharing options...
pulxar Posted September 15, 2008 Author Share Posted September 15, 2008 Thank you. I am looking for it now. Link to comment Share on other sites More sharing options...
k9sar Posted September 15, 2008 Share Posted September 15, 2008 (edited) I'd say he's smoking something cause I couldn't find that TSB in any of my files and I wonder how a 1993 TSB would be issued on a 94 model. Problem is that he is an authority on the mechanical aspect of this stuff so I dare not doubt him Edited September 15, 2008 by k9sar Link to comment Share on other sites More sharing options...
Precise1 Posted September 15, 2008 Share Posted September 15, 2008 I wonder how a 1993 TSB would be issued on a 94 model. They didn't fix it. Duh... B Link to comment Share on other sites More sharing options...
5523Pathfinder Posted September 15, 2008 Share Posted September 15, 2008 If it isnt found, I will print it off later today and copy it onto my computer at home, then post it up. Link to comment Share on other sites More sharing options...
pulxar Posted September 16, 2008 Author Share Posted September 16, 2008 If it isnt found, I will print it off later today and copy it onto my computer at home, then post it up. I did a few hours of digging, including going through Nissan's site and couldn't find anything. If you'd be willing to take the time to do that I'd appreciate it. Link to comment Share on other sites More sharing options...
5523Pathfinder Posted September 17, 2008 Share Posted September 17, 2008 here you go!!! http://npora.ipbhost.com//index.php?showto...mp;#entry338813 Link to comment Share on other sites More sharing options...
pulxar Posted September 17, 2008 Author Share Posted September 17, 2008 You ROCK! Thanks a bunch! Link to comment Share on other sites More sharing options...
